2017-05-02 01:40 AM
2017-05-02 07:15 AM
2017-05-02 07:49 AM
Barry wrote:Rather than just thinking about it I actually tried it.
I notice too that you can't even edit a 'Custom Text' field in the schedule for a module door.
This seems a little odd to me because even if you had the identical custom text field in a schedule in the original module file, I don't think it will transfer to the second file as the schedule is not part of the module and that custom text field is not part of the door as it only exists in the schedule itself.
2017-05-02 08:31 PM
2017-05-03 03:06 AM
2017-05-04 06:18 PM
Barry wrote:Thanks Barry.
Otherwise depending on the door object it may or may not have 'custom' parameters that you can use for the info you want and to can add these into your schedule.
Or use the Properties to store the info you want - sounds like you are already doing this with the fire rating, etc.
2017-05-05 02:49 AM
cdaubert wrote:Excellent.
Thanks Barry.
I was able to use the property manager tool and add custom properties to objects (doors in this case). Once I adjusted my door schedule to pull these properties it recognized them from the hotlink modules.
