2008-05-30 09:38 AM
2008-05-30 10:40 AM
2008-05-30 05:00 PM
2008-05-30 05:54 PM
2008-05-30 05:54 PM
Peter wrote:But is it actually cheaper to continue using 9?
...Much cheaper than buying a new copy of ArchiCAD!
2008-05-30 06:05 PM
Matthew wrote:True, but it would take several weeks and lots of work to get up to speed with AC12, all for the sake of opening up a survey drawing!Peter wrote:But is it actually cheaper to continue using 9?
I know the switch to the AC-PM unified format is a bit rough, but I think the payoff is well worth the effort, and then there is all the other stuff...
2008-05-30 07:22 PM
Peter wrote:Of course my point that the upgrade would more than pay for itself, DWG issues aside. Of course if it takes a couple of hours to sort out the one DWG problem (not unlikely) that would amount to a significant chunk of the upgrade cost (at least at the billable rates around here). Transition costs are another matter of course and must be judged on a case by case basis, but upgrades are inevitable - it's only the frequency that is variable. I imagine that few, if any, are still using AC6 professionally.
I wonder if it is actually possible to quantify the productivity difference between AC9 and the latest version. It would be interesting to find out! I should imagine just simple things like guidelines and integrated plotmaker must make a big difference.
2008-06-02 09:45 PM
2008-06-03 03:05 PM
2008-06-04 02:25 AM
