DWG Translators - Adding prefixes to layer names
Aaron Bourgoin
I am routinely saving DWG of layouts. ArchiCAD translators have begun adding the name of the sheet to the layer names.
I can find no way to disable this and I do not recall this happening in the past.
Can someone shed some light or let me know that it's always done this and I wasn't paying attention.
Thanks.
Think Like a Spec Writer
AC4.55 through 29 / USA AC28 USA
Rhino 8 Mac
MacOS Tahoe 26.0
7 REPLIES 7
DGSketcher
Legend
New one to me. Are you using the latest GS translator which may have options setup that weren't used in previous versions. Sometimes the templates get modified to how someone thinks would be better.
Aaron Bourgoin
I do think that's what's happened.
A new feature that went undocumented, and, or, a bug in a new feature that doesn't allow the user to make the settings for layers as intended.
Rhino 8 Mac
MacOS Tahoe 26.0
DGSketcher
Legend
It isn't a new feature, but you should be able to click on the DXF/DWG Layer name and change it to what suits your required working layers?
Aaron Bourgoin
this was the pane I should have included: I cannot edit the "<ACLayerName>" and I would guess that the associated prefix for sheet name would appear in this line as well.
Rhino 8 Mac
MacOS Tahoe 26.0
GOBA
I am not sure if this answers your question, but in order to map the ArchiCAD layer and DWG layer, you need to have a DWG template, with all the layers, so you can select them, after clicking “New” in "Layer name conversion":
Regards,
GOBA
ArchiCAD user since November 2109
AC24, Windows 10
Aaron Bourgoin
Hey GOBA, I'll check k that out.
BUT,
I didn't have to do this before. I've been using a template file to hand font styles, and nothing more.
Rhino 8 Mac
MacOS Tahoe 26.0
GOBA
Hi, I don’t really know if it’s new, or if there is another way, because I've just started to use ArchiCAD
AC24, Windows 10
