DWG embedded drawings
Hello,
I have the following problem, I attached as Xref one dwg file (with more others dwg linked inside it), i try all the translators settings with and without the import viewports as embedded drawings and please see attach to see the results.
I have in the drawings some elements on Archicad layer impossible to hide, delete or else.
I assume are some drawings as I see in drawing manager, also impossible to delete...
My question is how to delete/hide them?
Anyone found out this problem?
Thank you.
0 Replies 0
