DWG to GSM
It is possible to convert a dwg object into gsm object??? Please anyone help...
How can i make it?
Or how can I use a dwg object in Archicad?/for example a chair/
3 Replies 3
David Maudlin
Dorak:
One thing you can try: go to Open Object..., select Browse for a Folder, change Enable: to DWG file, the find and open the DWG file you want to convert. This will open the DWG file as an object, save this object into one of your loaded libraries to use in your project. Not all DWG files will translate properly. This is for ArchiCAD 14, earlier versions work a bit differently.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Erika Epstein
There is also a [DWG]translator option which will convert autocad blocks to archicad .gsm library parts
Make a copy of a translator and rename it appropriately.
FILE>DXF-DWG Tranlation Setup>Settings in Selected Translator>Open Options>Open as Floor Plan> Translate AutoCAD Blocks as
and from the drop down menu choose Library Parts.
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
