Dalux plugin problem with "Duplicated External ID in Elements"
Leaenota
I tried Dalux for the first time and ran into a problem with the plugin. I was wondering if someone have encountered this issue before.
When I perform a DaluxBIM Upload, the 3D model in Dalux does not display and shows the error message: "Duplicated External ID in Elements." But all of the Archicad IFC IDs and the Unique IDs seem to be different from each other... And if i understand corectly Archicad creates an external ID from the Unique ID when you export it...
I managed to narrow it down and found that this problem occurs when there are openings created with the Opening Tool. Have someone come across this issue before?
0 REPLIES 0
Setup info provided by author
