Dimension lines change when exporting DWG
Hi there,
When I export a file to DWG and look at it, if I have used a dimension line that uses a witness line set up with a dynamic witness line, it ends up running the witness line all the way to the source of the dimension... In fact it does it in every case, unless I chose to have no witness line.
Is there some work around other than having no witness lines on my dimensions?
It didnt do this in v8.0
Currently running 8.1 r2v2
Update: the file opens perfectly in autocad, and earlier versions of archicad, but dim lines run all the way through when opened in AC 8.1 R2V2
