Josh Griffen
Door Leaf Thickness in Schedule
Is there a way to show the door leaf thickness (i.e. 1 3/8" or 1 1/2", etc) in the door schedule? The "Nominal W x H x T Size" gives the frame thickness and the "Leaf Dimensions" gives the width x height. Nothing seems to show the thickness of the leaf.
Archicad 22
Windows 10
3 Replies 3
If there is a parameter in your door object for the leaf thickness?
If yes then you can add that object parameter as a field in your schedule (or any other object parameter you want).
Click the (edit) arrow next to the 'Add Fields' button and choose "Library Part Parameters'.
Then browse for the library part and find the parameter - I believe it is 'gs_leaf_thk'.
TENNIS-LIFE
There is a parameter called "Door Leaf Thickness" in the object.  However, I see no "Library Parts Parameters" in the "Add Fields" lists.  Can you grab a screen shot for additional guidance.  Not also that the L x W x T field, which one would think are leaf parameters, instead shows less parameters for "L" and "W", but wall thickness for the "T" parameter.  This is absurd.  Perhaps we can change the "T" parameter in a way that solves this problem(?)
Sorry, click the arrow next to the 'Add Fields' button.
