Door Schedule - (2)3'-0"W doors
Does anyone know how to describe a pair of 3'-0" wide doors as that?
I have tried most double door library parts and in the schedule they all describe themselves as one 6'-0" wide door.
4 REPLIES 4
Srinivas
Here is a workaround suggested earlier on the forum, it would be required to create your double doors with 2 doors as suggested as it is not possible to show a single double door object like the way you wanted it to be listed on the schedule.
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
Ok, thanks! I must have missed the earlier posting. I don't think the work around is going to cut it for this application, but it's good to know that I'm not missing a better way of doing it.
Christine,
Look here... the last post.
If you are willing/able to use some gdl, this will work. BTW, this is the only option that we felt was acceptable.
Would be great to have Graphisoft update the AC14 Library to do what jbissaillon explains here
