Door Schedule Parameters
So I have a storefront door that I am able to input overall storefront height and width. I am also able to input the size of the sidelight panels and by default the remainder is the door width. So technically there is no door width parameter which is a problem when it comes to the door schedule.
The door schedule shows the overall wxh of the storefront, which is 14'x14. But what i need is the door wxh.
How do I get this information on the schedule if there is not parameter for it?
4 REPLIES 4
You can't unless you want to edit the object to add a parameter that will show the calculated value of the door width.
Then you can list that parameter in your schedule.
Thanks!
I am not being successful on editing the door. I don't see where or how I can edit? Any ideas?
David Maudlin
douglas:
You have to open the door library part (Open Object...) then add a parameter, in the Help files see: User Interface Reference > Dialog Boxes > GDL (Geometric Description Language) > GDL Object Editor, Parameters. This takes some understanding of the GDL environment in ArchiCAD.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
