Achille Pavlidis
Door Schedule layer dependent...
If I understand correctly since doors&windows do not have layer association it's impossible to have a Door Schedule that lists only doors that belong to walls that are on specific layers.
I'm correct?
Mac OS 26.1 | AC 29.1.0 INT 4006 FULL
6 Replies 6
Wall layer can be taken into account in door & window schemes. See pic.
Achille Pavlidis
Yes, but does it effect the doors schedule?
Yes of course. A door's layer is associated to its wall's layer.
Does anyone know how to select the desired layer combo for a door schedule. I thought when I created the schedule it would use the currently active layer combo, but when I clicked on the view it gave me a completely different combo. Also, the layer combo option is grayed out in the view so I cannot retroactively change it. Uggh!
The combo isn't used by the schedule. It's a weird artifact that the active combo (if any) is saved with a view and is then uneditable. You can open the view, change the combo and then just redefine the view.
Ahhh. Now I see it. There is a button in the top left corner of the view that reads "Get Current Window's Settings". I missed that. Now it works.
Having the correct combo on makes a difference when trying to edit lines in the schedule. Locked layers are not editable.
Thanks!
