‎2012-07-04 10:53 AM
‎2012-07-04 06:22 PM
Fotis wrote:No. The element scheduler is not capable of that - given the data fields you choose to display, it always displays either 1 line (record) for each element (door in this case) - or 1 line for all identical records. But, you cannot combine multiple fields (zones in this case) into one line that shows all values associated with something else.
Can I combine the zone number field in one column separated by commas and have only one listing for every door type?
‎2012-07-05 04:28 PM
‎2012-07-05 06:30 PM
Fotis wrote:No, GDL objects do not have access to data about any other objects/elements - only to the zones in which they themselves reside.
Do you think it's possible:
1. to create an object (let's say a custom gdl dimension marker)
2. that counts takes data of all the doors of the same type (ID number) and create a custom text value
3. and then place that value on my schedule instead of the zones numbers directly?
Fotis
‎2012-11-11 01:57 AM
‎2012-11-11 01:55 PM
