Tincan561
Door & Window Schedule Add Fields...
In the out-of-the-box Archicad 22 template, in the door & window schedules the width and height are set by fields "A" and "B". The door thickness is controlled by "Panel Thickness"
How does one access these fields?
If I delete and try to re-insert them with Add Fields... they are no longer available.
Archicad 26 Macbook Pro, Ventura 13.6.3
1 Solution
poco2013
Mentor
Under the ADD button select the drop down arrow and then library part Parameters.
under your library - probably Object library 22 -- openings. Select the door style and it will list the available parameters. The lower right pane will show the parameters already selected so it might be a good idea to note the variable names before you delete them as many parameters names are similar.
Gerry
Go to post
2 Replies 2
poco2013
Mentor
Gerry
Tincan561
Thank you.
