Tincan561
seit ‎2015-10-04
‎2025-05-17
Benutzerstatistik
  • 55 Beiträge
  • 0 Lösungen
  • 4 Vergebene Kudos
  • 1 Erhaltene Kudos
Benutzeraktivitäten
I am having great difficulty transferring properties from my Favorites menu.Specifically, I am unable to double-click and transfer any Drawing properties.I can select settings from a placed Drawing with the eye-dropper and inject the properties into different placed Drawing....
Can someone explain why black dots appear on some manually placed zones? They seem to appear when the zone boundaries are colinear with walls. What are they and how do I turn off this feature? Thank you.  
The planning department for our county insists all submittals are in DWF format. I have no difficulting publishing a sheet in DWF format, or even Save-As in DWF format.When I open the newly-created DWF file in AC26, everything appears perfectly to me - the 1:40 graphic scale...
What happened to gradient (drafting) fills in AC26?They are not in the Archicad 26 Template (US).I can copy and paste these fills into a file from AC25 into the file.They appear in the Attribute Manager, but are not accessible from the Menus.They appear as MISSING.  
I have a simple railing where the two rails and inner posts are the same depth. in elevation and model the rails the railing lines continue although I prefer that the rails stop at each inner post. Is there any way (without changing the depth) that I can have the priority of...
