Door and Window Builder ???
After and exhaustive search In DWB and in the forums I give up. Is there a way, for the door schedule to list the nominal door panel size as opposed to the entire unit (door panel and jamb). For example if I have a 3'-0"x8'-0" door, the schedule and even the width and height parameter in the door selection settings will list the combined door size and jamb thickness, which is not the correct way to label the door size. Is there a setting similar to the AC12 library door settings to check the "Nominal Size"?
Thanks,
Jim
4 Replies 4
Anyone? I know that there are some DWB gurus here that could answer this.
Thanks again,
Jim
Brett Brown
Did you email them? Are you using DW Builders own schedule? If so is this what you are after?
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
Thanks Brett for the reply.
I want to use the Interactive Schedule. But it doesn't matter what schedule I am using, the width and height parameter in the door selection settings will list the combined door size and jamb thickness, not the nominal door panel size.
Jim
Stress Co_
I would email CadImage support and ask:
customer.care@cadimagetools.com
Also, they have their own forums:
www.cadimagetools.com/resources/forum.aspx
EDIT:
I'm with you on this..... in the past I've made (dwb) door panels smaller, just so the size would be "right" in the schedule/door marker.
Marc Corney, Architect
Red Canoe Architecture, P. A.
