Door and window schedule scheme setting 'view from outside'
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2020-11-16 10:24 AM
- Labels:
Data management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-17 09:17 AM
By the way, it may not be possible to do, because it is totally random which instance of multiple Doors/Windows that view is generated from in the Schedule.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-17 11:37 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-18 02:35 AM
Then use the 'View from reveal side' to get what you want?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-18 03:41 AM
So long as you place your doors with the reveal on the outside of your wall (first placement click), then the 'view from reveal side' will be accurate - i.e. as viewed from the outside.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-18 02:34 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-19 02:31 AM
It looks like they use a solid line on the inside and a dashed line on the outside.
I am unsure at the moment if the side the dashed lines are on is linked to the reveal side or the door/window orientation.
If it is linked to the reveal side you should always have consistency if you schedule the view from the reveal side (and transparency is turned off).
If it is linked to the orientation then you will have trouble if you schedule from the view from the reveal side
So of course when ever you have transparency turned on you will see a solid line - you are in fact seeing both lines.
Is there any control in the objects (or MVO settings) as to the line types used?
I will see if I can have a look a little later.
Barry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-19 09:28 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-19 10:25 AM
The line type is indeed linked to the opening (orientation) of the door/window.
So you are going to have a problem if you use the view from reveal side as the lines on the reveal side will change depending which way the door opens.
Plus I can not see a way to turn the transparency off in a schedule.
I am not even having any luck playing with the Graphic Overrides.
Myself I have the same line type inside and out so it looks the same no matter what.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-19 10:43 AM
It is very odd that we cannot change the transparency of the glass in the schedule. By manually overriding it, it will give a problem further on in the proces when we make views of the inside walls, since the lines will not correspond with the opening anymore.
Should I make a new topic about this?
