Door casings in Schedules
I would like to show the door casings in the plan views of the door schedule. Is there a way to do this?
1 REPLY 1
If there is no option in the door parameters to show the casing in the schedules then your only ption is to edit the object scripts yourself - but I don't recommend this uless you know what you are doing.
See a similar post here ...
http://archicad-talk.graphisoft.com/viewtopic.php?p=221346
