IFC inconsistency
Hello guys,
When I want to import an IFC-file that I've made in Revit, I am constantly getting the following message:
"Inconsistency found during IFC file read operation!The operation will be aborted."
I've tried importing the file on different ways, but I am always getting the same message.
Does anyone know what the problem could be?
Thanks!
René Sondermeijer
6 Replies 6
What you should try is check the IFC file with a free IFC Viewer application to see if the problem is in Revit or not.
If the IFC Viewer also gives the same error messages then most probably the Revit output is not good. Then something needs to be done on that side.
If, not, then we can take it up again. Let us first see the Revit side.
Hi Rene,
I find the archicad IFC importer intolerant of non-compliance to the IFC schema, so you may find that viewers etc will display the file. The import process is abandoned and I can't find if it logs anywhere any advice on what the issue was.
I have found that if you fix any non-compliance with the schema (and there are online verification tools) that the file will open. Unfortunately this probably needs an adjustment to the revit ifc exporter. Can you confirm if you have installed the latest build of the exporter (which is updated frequently now as an open source project). The issue might have been fixed as the exporter is now certified.
If you can post or send a sample model, I can take a look.
Also as Laszlonagy suggested, DDS cad viewer is freely available and good at reporting non-compliance of a file.
Jon
Thanks for your replies. My apologies for not responding this late, I had very little time for this issue the last weeks.
But back to the subject. I have tried the following things after your replies:
- I have installed the IFC exporter 2013 for Revit. I've made an ifc-model of the model an tried to open it in Archicad. No improvement.
- I have installed some ArchiCad updates, also one involving IFC improvements. No result.
- I have downloaded DDS Cad viewer. I can see the model. I only don't know how to check for non-compliance.
Maybe you can check it for me? I have uploaded the file into this comment. Its a very basic one.
Thanks!
Are the trees required for the transfer? The verification tool doesn't like the annotation category assigned for their shape representation.
It also doesn't like the fact some elements have no material assigned which seem to be stair stringers and landings.
No they aren't. But I also have got the problem with other IFC-models which only consist of building material.
I tried opening the exact same file on another pc, but that did work without any problems. So it is sure that the problem has to be found in ArchiCad.
davdelven
I attached you the files you uploaded. Apparently, AC22 can import it, no errors.
[img]
Thanks!
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
