Door schedule (thickness)
Is their a fix to this? The problem I am having is I have a custom door schedule (IS) and in the thickness field (leaf thickness) It sould read 1 3/8", instead the IS rounds the number off to the nearest 1/2". So now it reads
1 1/2" as opposed to 1 3/8". Same if I have an 1 3/4" thickness, it reads 2".
Any Ideas?
Thanks,
Jim
3 Replies 3
Just throwing this out there a possibility, I really haven't test this theory.... but maybe it could be in the dimension setting in AC preferences. Try experimenting with the fraction settings..... and let us know if that makes it work
Scott has the right answer. In your preferences, under dimensions, make sure that you have one for schedules that has the right tolerance for fractions.
You guys are correct. Thanks
Jim
