There are different ways how to get a door schedule like that, but I guess you'd like to know if it can be generated like that without further manipulation. Although I have spent quite some time to experiment with schedule settings I was not able to get a schedule which wouldn't need further editing - in my case I always have to manually add some dimension lines (sometimes even enhance the door drawing as the default library part options are limited) and add the final description on the layout, where the door schedule drawing is placed.
The door/window schedule tools could use an update.
| Archicad 4.5 - 29
