Eco Designer Installation
Hi Guys
I was wondering if someone can help me solve this issue.
I just purchased Eco Designer for ArchiCAD 14. Once i install Eco, ArchiCAD tells me my the eco designer add-on is out of date for this version of ArchiCAD 14.
The Eco designer disc is for AC14 installation. My AC is up to date with the latest hotfix which i believe is 3477 atm and dongle shows all my products up to date and registered now showing Eco designer.
I then downloaded eco designer version 14 from Graphisoft's website and installed it with the repair option. I still have the same problem. Eco designer add-on is out of date.
When i load AC14, Eco designer's logo does appear on the loading image top right hand corner so i know at least its installed properly.
My Current system info is
I'm running on the latest mac update OSX 10.6. Running AC14
everything is up to date and starting to get annoyed. I've sent this issue to tech support with Graphisoft which they have no resolve yet.
I even unistalled everything! and reinstalled AC14 starting from version 3004, installed eco designer and VBE. VBE works fine, eco designer still said add on is out of date and eco logo showed on AC 14 load screen. Then i updated AC14 to Hotfix 3477 and still not working! still out of date add-on
I've done everything that i can think of has anyone got eco designer working on a mac????
0 REPLIES 0
