Hello
I do it that way in these cases:
1. Assigning as PredefinedType attribute: USERDEFINED
2. Filling the ObjectType as your own custom type: "RAISED ACCESS FLOOR"
I think it's the aimed and right use of the Userdefined option on PredefinedType attribute field, using de OBJECTTYPE description.
Check with IFC File Analyzer (NIST) your IFC and generate the Spreadsheet, and you'll can see the results.
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC26 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
