fuzzytnth3
Element Classification - "Building Element Proxy"
I am trying to make sure an IFC I am sending out to share with the Contractor and other Consultants has the correct Element Classification.
My walls and ceilings are all fine but the Raised Access Floors the only choices I can see are "Slab" or to use "Building Element Proxy" and then add an IFC Description that says what it is ie "Raised Access Floor"
Am I doing the right thing or am I missing something?
thx
Using AC25 5005 UKI FULL
davdelven
Hello
I do it that way in these cases:
1. Assigning as PredefinedType attribute: USERDEFINED
2. Filling the ObjectType as your own custom type: "RAISED ACCESS FLOOR"
I think it's the aimed and right use of the Userdefined option on PredefinedType attribute field, using de OBJECTTYPE description.
Check with IFC File Analyzer (NIST) your IFC and generate the Spreadsheet, and you'll can see the results.
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
