Element ID Manager
Im a bit confused with how the ID manager works, sometimes it works as how its been explained to me and sometimes it doesnt.
When I was taught how to use this manager it was that you could select them in order, then use the ID manager to apply a change to them and they would change in the order you selected them in.
Sometimes they change in the order that I select them in and sometimes they dont.
Sometimes most of them will change in order and one or two will change to be out of order.
Sometimes they will just be completely randomly assigned the ID's no matter what order I select them in.
Can someone explain maybe what I might be doing wrong?
Thanks
1 Solution
Make sure you don't have "Element ID' in the selected criteria.
Go to post
3 Replies 3
Thanks Barry, works great now!
artktecture
I was having the same issue.
Thanks for the solution!
artKtecture uses Archicad 24/Twinmotion
Lenovo Thinkpad | Xeon [email protected] GHz | 32GB | Quadro P4200 8GB
Oculus Rift S VR tours
Contour Rollermouse Red Plus (ditch your mouse and get one of these!)
Using a highly modified Shoegnome template (Thanks Shoegnome!)
