2005-06-28 07:39 PM
2005-07-03 10:29 AM
2005-07-06 02:25 AM
gobel wrote:They should be able to edit the layout in paper space. I haven't had occasion to check this myself though, I rarely send DWGs on titleblock.
Hello Everyone,
I really have a serious problem now, i work with AC 9 B2045 and i have a big problem publishing my plotmaker book to DWG so i can send it to the contractor, here are my problems:
1. They can not add any pen assignment to the layout or add any style in the autocad. I tried to make conversion table for the pen colors but nothing work.
2.all the back ground fill that it's white in AC goes to autocad as a color fill and turns to black when the plot.In ArchiCAD you can set the Display Options to show background fills as all transparent. This will suppress the backgrounds in the DWGs. I assume the same is true for PlotMaker.
3. If they delete these background fill, so the other fill for anything like floor pattern appears and doesn't trim. So at the end a bad result.There is an option in the DWG translator to export fill backgrounds as separate solid fills. This may allow them to be more easily deleted/hidden. As far as not trimming... I don't know why they would be inoperable in AutoCAD. How well does your contractor know AutoCAD? (No offense intended, I have known competent engineers who know only as much AutoCAD as they need, and have trouble with anything out of the ordinary.)
4.The arabic font on zones, turns to ?????I don't understand what you mean by "?????".
5. all the Western fonts turn to something else.Font mapping in the translator should be able to take care of this for you.
2005-07-08 03:31 PM
