Export to AutoCad/ dwg with survey/map-coordinates
Is it possible to export an archicad project to dwg with survey/map-coordinates instead of the local project coordinate system?
This is what I have done so far:
- Imported dwg-map into a worksheet
- Moved/rotated it as a trace under the plan
What I would like to do now is to export the plan and the trace with the map-coordinates, so that the entrepreneur may read out coordinates from building elements in the dwg-file, as they require.
A workaround I have found is to copy/paste the plan into the worksheet before export, but of course this must then be done with each revision to several worksheets. And when several floor plans are to be exported, it's not an option in the long run..
Best practises otherwise,,,, I am a newbie in Archicad,,,
Nor72
0 Replies 0
