Exporting DWGs and my curtain wall disappears.
iausesthis
When I export the sections to dwg, the curtain walls disappear. I found someone asked the question before, and someone said to refer to this as ARCH-7182.
I can't find a way to fix this though. Is there a way for me to fix this?
Thanks in advance everyone!
1 REPLY 1
Ola Zawada
Hey, make sure to use the Publisher Set every time. You probably used the Marquee tool.
Ola Zawada
BIM Manager, BDM'A
Archicad in my ā¤ since 2010
Setup info provided by author
