Exporting to Autocad 2005 to suit a preconfigured CTB file?
A client using Autocad 2005 wants us to export Dwg's from Archicad 9 so that they can use this information with other consultants. We have no problem with the request and we would like to help them.
BUT can we create a dwg file either from a Layout Book or Archicad to suit their set of preferences (which they are going to email over in the form of a CTB file). No doubt this will change with time?
We understand there is a problem with "editting" fills. We can avoid this.
What we need to do is match or synchronise with their preferences.
As always we would like to hear of similar experience.........?
Djordje
Ask them to eTransmit you their template DWG file; use it for the definition of styles, linetypes, layers, colors, etc etc etc and as yout template file in the Translator.
All should be well.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Many thanks for the advice it most appreciated. We will put this into action and hopefully meet their expectations.
kind regards
HLPBob
