leishe
File broken into thousands of lines after exploding into current view from PDF to Archicad file.
I am new here. When I explode the PDF file into archicad, it doesn't recognize text, objects, lines, doors, or anything and has simply broken the pieces apart into thousands of lines. Help?
1 Reply 1
You won't have objects, doors, walls etc.
You will end up with just lines, fills and single line texts.
That is all a PDF contains.
That is only if the PDF is saved from a vectorial program like Archicad.
If it is a scan from a printer it will not explode at all as it is just a bitmap image.
