File size DWG-PLN conversions
I am having trouble with the large files generated when I convert into
Autocad from Archicad and vice versa. Sometimes the difference factor will be 10X. Is there a simple way to cut down size without losing the drawing essence?
__archiben
turn off your fill display . . . does that help?
~/archiben
b e n f r o s t
Thanks Ben- that makes big difference
Another one is: make sure your line weights are set to Hairline.
