2021-06-15 03:06 AM
Solved! Go to Solution.
2021-06-15 04:09 AM
2021-06-15 03:32 AM
2021-06-15 04:09 AM
2021-06-15 04:11 AM
2021-06-15 02:42 PM
Richard wrote:This is a major help, Richard! Thanks!
Just as I suspected, I had a look in the GS standard template and found the finish schedule you appear to be using. The Property Manager can be your friend. You will find this Option Set to be infinitely adjustable. You can also add other properties which can show up in your schedule, too, and assign them whatever standard defaults you'd like to use through the Option Set.
2021-06-15 02:44 PM
Karl wrote:Thanks, Karl! Learning every day, thanks to you guys!
(I've moved this topic to the Data Management forum - which includes discussions of the interactive schedules, properties, etc.)
Adding to Richard's post: the schedules that come with the template are mostly examples just to help you get started. All schedules are customizable.
