Goodies, Add-on Archicad 13
Hi
In Archicad13 I loaded the Goodies, and even with the Stadard Work eviroment, the Roof Accessory dosen't show up with
Please any suggestion?
Thanks
5 REPLIES 5
Hi Giuseppe,
This caught me out as well! You need to go to the library manager and add the folder typically found here -
C:\Program Files\Graphisoft\ArchiCAD 13\Accessories Library
In AC13, they have put the accessory libraries in their own lcf file which gets installed at the same time as the accessory addon.
Hope that helps!
Thank you so much
I do not have suc folder as Accessories Library in AC13 MAC
I need to use the Roof Surfacer.
Thanks for any help
Adalbert,
The link to the goodies is found on the Help menu within ArchiCAD. Look for 'ArchiCAD 13 Downloads'. This should take you to the localised version of that page.
The link above is for the INT versions of the goodies which may not be compatable with other versions.
