Help - IFC export fails on OS X with network homes
Hi there,
We're using OS X Server 10.6.8 in combination with network home directories. Everything works fine, except the IFC export.
We're trying the following:
1. Save any file as ICF 2x2
2. Edit Options/Preferences of this Plugin
Whenever we try anything oh the above as being logged in as network use, the task fails with the following error:
EDM Error - Code:0 - <Fatal Internal Error>
When we are logged in as a local user, everything works fine. I've found the following in this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?p=155502
It seems to be the same error more or less; but without network homes. In the following threads
http://www.archicadwiki.com/Bugs/IFC/EDM_Error_11059
(we deleted the folder and checked permissions)
It seems that the Path to the EDMDB-Folder path is too long; with a network home it is:
/Network/Servers/first.ooszrh.ch/Volumes/Vtrack/Users/heinz/Library/Application Support/Graphisoft/EDMDB
then we get the error.
then everything is ok.
I know that the path should not be longer than 127bytes (please see http://www.archicadwiki.com/Bugs/IFC/EDM_Error_11059); I think it is not, but it has to be the problem. We tried to set a folder redirection and hard links to the local path - nothing helps 😞((
Does anyone know what to do? How can we change the path for EDMDB-folder? Or what else can we do? Archicad just has to work with network homes!!! 😞
Thanks for any suggestion!!!
All the best,
Goofy
0 Replies 0
