‎2010-12-18 07:53 PM
‎2010-12-18 10:27 PM
‎2010-12-19 08:41 AM
TMA_80 wrote:i'm using sketchup 7 and archicad 12 windows xp sp3....thx's
Which plugin have you downloaded?
‎2010-12-19 08:55 AM
‎2010-12-19 12:35 PM
TMA_80 wrote:how can we know about which plug in we used...? thank you
There are two Sketchup plugins for ArchiCad12...
Anyway, try to save your Sketchup file as skp version5. ( The Sketchup plugin has a problem in importing any newer skp file version than that)
then try to open it again in ArchiCad...
‎2010-12-19 02:14 PM
‎2010-12-20 08:37 AM
TMA_80 wrote:I Try both of them ( Plug in )...and save file to .skp 5...but the file was empty when i opened in archicad 12...sometimes when i'm opening skp file with archicad 12..there was a bug reporting.... thank you all...
so if i'm not wrong:
If you install this one it will open directely from file / open ( *.skp should appear as a file format choice ) this will transform any skp surface into walls, slabs, roofs...
however, if you install this one it will open directely from file / open ( Google WH Sketchup .skp should appear as a file format choice ) it will import directely your skp file as an object
In both cases, save your skp file as skp 5th version before importing in Archicad
‎2010-12-20 08:59 AM
