SOLVED!
Help me buying new laptop
kornclub
Hello , i am buying laptop but too much configrations and varaties , i am confused what to chose !
Recommended Graphics Cards for Archicad 25  Nvidia Quadro K, M, P and RTX series.
any recommendations ? or specific laptop can do the job done Medium projects
Thanks
18 REPLIES 18
Solution
This is correct, however I also have a laptop with a 2080 and a 2060 with identical components otherwise and the 2080 is much better in Archicad with 3d vs the 2060. Noticably.
But my 3070 kills it in twinmotion for sure in comparison to the other two. Even only being slightly faster than the 2080.
awesome! you guys talking about just using laptops with RTX GPUs performing that much! I can't wait to upgrade my desktop with 3080, its just way too expensive! 😆
WINDOWS 11 PRO
I am looking at the Msi creator z16
14 core and 3080!
This will be a monester labtop , truely it is expensive , i will check RTX 2080 to see possibilities many thanks it is very nice to understand from others experience
My pc   i9-9900KF CPU@3.60GHZ (16CPUs),mEMORY 32768MB RAM ,NVIDIA QUADRO RTX 4000 Approx. Total Memory 24367 MB -Display Memory (VRAM) :8018MB ,Shared Memory :16349MB
kornclub
i ve found offer but i wonder if it is good or not
  • Laptop Gaming ASUS TUF F17 FX706HM cu procesor Intel® Core™ i9-11900H, 17.3", Full HD, 144Hz, 16GB, 1TB SSD, NVIDIA® GeForce RTX™ 3060 6GB
17in quite big but specs wise looks good! 😎
WINDOWS 11 PRO
Mainly i want to use it since Covid and worked from home I was thinking with a good laptop i can travel and work when ever i can ,i had bad experiences with laptops so i ve decided to buy better performance to support Archicad and other 3d programs . when i merge IFC strucure files into project that is the main problem too many bolts and plates makes Archicad to suffer and me too even to orbit tell i succeed to isolate layers .
I was checking MSI website and you can chose what you want it for but the problem is prices , sometimes i feel it is over priced that is why i wanted to see others experience with laptops ,medium projects, Charts with Graphisoft GPU didn`t help much to chose .
ryejuan
there is no one solution to buying a hardware for software it can vary, especially you're handling IFC with lots of bolts and plates for sure it will cause a huge lag on your system. Not sure if I'm correct but investing in a good processor adding more ram will help in loading those bolts and plates faster. Like i told you earlier if you are planning to do real time renderings etc. you can fully utilize the GPU's power that would be nice as well.
WINDOWS 11 PRO
I will wait to hunt offers and let you know if it was a good choise or not , I saw RTX 4000 best solution but expensive solution with i7 or i9  H  and ram 16+ should do the job done
hope to find a good offer ,manythanks for replies
