How do I load MEP library?
Greetings guys,
I just started using Archicad MEP modeler and I wanted to give it a go and build a simple system just to test the software. But I am unable to do so because I cannot seem to find the pipe/duct library. Can you please help me find it? It should be straight forward I think but I guess I am missing something. Best regards,
David Maudlin
milangomes:
Look at Applications > Graphisoft > ARCHICAD XX > MEP Library XX. Use the Library Manager to load the library.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
vfrontiers
Loosely related... How do you UNLOAD MEP Modeler?
I tried just unchecking in ADD ON MANAGER, but you can't.
I tried just removing the MEP Folder from the ADD-on folder, but it won't start archicad without it in there.
I find MEP of no use to me and when installed it takes over some of the base cabinet objects making it so I can't change a 2-Door Base Cabinet into a Multi Drawer Base because the drawers are not MEP blessed...
Any advice would be helpful!
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
The MEP Modeler is a separate installation.
So I would suggest that you use the Uninstall command to remove it.
