2006-11-20 10:15 PM
2006-11-20 10:42 PM
2006-11-20 10:45 PM
2006-11-20 10:50 PM
2006-11-20 11:10 PM
2006-11-20 11:40 PM
2006-11-20 11:47 PM
Erika wrote:As Link stated you need to bind them. But before doing so make sure all layers are unlocked. If a layer is locked, it will not bind.
I received 5 dwgs that seem to be Xrefs with site information.
I am unable to edit them. Any element I select gives me the following message:
"this is an item of an attached Xref file and cannot be edited"
I have checked that the translator is set to editable and that all elements and layers are unlocked and ungrouped.
I've tried opening them in AC9 with the same results.
What am I doing wrong?
Do I need to instruct them to embed somehow, and if so please explain the correct terminology, the xrefs into a dwg so I can work with the elements?
Thanks in advance,
All help welcome,
Erika
2006-11-20 11:56 PM
Thomas wrote:
But you may not need that if you can see the file's contents.
- Unlock all layers
- Turn on Groups
- Select something (now the whole file should be selected)
- Turn off Groups
- Copy (now this will copy each indivdual item instead of the whole thing)
- Paste
Now you should have an editable copy of the dwg's content. Turn off the Xref by it's Master layer, and start editing.
Mark wrote:Are you guys sure about this??
2006-11-21 12:52 AM
Link wrote:Actually, i just tested it. I am wrong. This use to happen to me in ArchiCAD 9. I just assumed it happened in ArchiCAD 10, but looks like it does not happen anymore.
Are you guys sure about this??![]()
Link.
2006-11-21 02:14 AM
