How to convert attached CAD file in ArchiCAD library
Hello All
Can you please help, I am looking to convert linked CAD file to GDL (ArchiCAD library object). I have several other files similar to the linked one that I will have to convert to GDL. Any help is appreciated.
Thank you
Dragan
https://drive.google.com/file/d/0B29OCy4YH8owV1EzLXlGQTZDcXc/edit?usp=sharing
2 Replies 2
Eduardo Rolon
One procedure to try:
Import DWG in AC
Explode DWG
Select lines and Convert to Morph
Select Morph Lines and File->Libraries and Objects -> Save selection As
this is provided that you want to convert 2D lines to 2D Object.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Thank you,
However my CAD files are not 3D lines i guess I will have to convert CAD files first.
Will try this morning.
