One more question regarding schedules: I've been interested in collapsing my door and window schedules to show the individual instances of each element. I've also needed to keep the room/zone name and number to be able to locate these elements efficiently, so just about every instance of an element is an individual entry in the schedule.
I would rather not have a manual work around to list all these locations in one cell, so I've been pondering if there is a way to collect this automatically, and can't find a way to do so.
With the location, room and number, there seems to have been a workaround changing parameters in the GDL, but that seems to no longer work:
https://archicad-talk.graphisoft.com/viewtopic.php?t=48107
With regards to how one does this, I thought there might be a way to use Tags from the Property Manager to do this, but I would still need to have that info called from somewhere and would be redundant to using the properties that list that information. But then there seems to be no way that multiple instances of some information can be collected together anyway. So then what ? The Sum functions in the schedule can only be used for column numbers/integers throughout a column, but not for text in one cell... ?
