How to export point clouds(.e57) to IFC ?
hiro siba
I need to export point cloud to IFC from a model . Is it possible to export point clouds to IFC?
I already trid to export point clouds to IFC. But The following message appeared ''Could not export because the geometry of the following element is missing: .''.
Do I need to change any settings?
Kevin Lee
Archicad is not able to convert point clouds to IFC. AFAIK, I don't think any BIM solution has the ability to include point cloud data in the ifc.
However, you can link point clouds using BIM validation software like BIMCollab.
Kevin Lee | Director of Technology | BIM
TZG Architects
ARCHICAD 27 | GDL | Rhino.GH | Solibri | Twinmotion
Mac Studio-M2 24‑core CPU | 60‑core GPU | 128GB memory
Bawar Tanay
@hiro sibai dont know why you will need to convert pointcloud to ifc, as Kevin Lee mentioned you can open it using BIMCollab.
but there is a workaround, when importing a pointcloud (.e57 or .xyz) into archicad it becomes a archicad object.
this object you will need to convert to a morph and then you can how to export using your ifc translation settings.
be aware that the whole pointcloud one big chunk of morph that also means that this will be quite heavy and probably will crash archicad.
#disclaimer i never used this workaround and wont know if it will work, and yes there is no advantage of doing this, as it becomes quite heavy.
i guess you lost your original pointcloud file?
Archicad 16 - 26
Laptop: Alienware M18 R1 | windows 11 pro | i9-13900HX | RTX 4070 8 GB | 32 GB RAM
PC office 1: windows 11 pro | I7-10700 | RTX 2060 6 GB | 32 GB RAM
PC office 2: windows 11 pro | i7-12700 | RTX A2000 6GB | 32 GB RAM
schagemann
Don't think that you can achieve this with Archicad, but depending on the complexity of the Pointcloudmodel you could try RHINO 8, which has a ShrinkWrap command...
https://discourse.mcneel.com/t/rhino-8-feature-shrinkwrap/149658
...have not tried it yet, but it looks promising.
Regards, DS.
macinteract
Design Technology Managers.
All  on macOS | since AC 6
Archicad Framework > Smart Template 27
Smart Tree, Transmittal and Universal Label and other smart GDL Objects
By Architects for Architects.
