I can't see my attached Xref on Worksheet
I'm new to ArchiCAD and I'm following this video, with same dwg for external reference downloaded from here, but when I attach it, the Xref's drawing does not appear at all. I tried by drawing another dwg myself with an Educational AUTOCAD 2020 and attach it too, but it doesn't work either. It seems I can't see any Xref I try to work with my ArchiCAD.
Only difference from links is that I'm using an ArchiCAD 23 BRA.
2 Replies 2
Hello Max,
Do you do a right clic and select "OK" after importing your dwg ?
Do you activate all your layers ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Lukas Zeleny
DWG import is different in archicad 23. It imports elements as "new" in renovation status. So you have to change renovation filter to see them.
BIM Manager at SIEBERT+TALAŠ
www.sieberttalas.com
