I'm trying to open 3d in archicad25 but mesh and roof attacked by this colour I need help
Blaise Design
2 ACCEPTED SOLUTIONS
Ady84a
It means that the photo of the texture is missing. you can select the mesh and check the texture. or assign a new material.
As Ady84a said, check out the surface texture that has been used for this mesh, go to option > attribute manager > surface > click on the mesh surface > click on the arrow and then browse texture > change the image or load image or texture from library:
Martin Luther Jules
AC 10-28 (Full)
Asus | 64 GB RAM | Windows 11
Ady84a
Martin Luther Jules
AC 10-28 (Full)
