IDs not showing up in schedules
Can' get window or door IDs to show up in SCHEDULES. HELP!!!!!!
10 REPLIES 10
Have you added a field for the element ID in the schedule scheme settings?
You may need to post a screen shot of your schedule settings and the schedule output so we can see what you are trying to do.
Yes I believe I did. Will pst some screen shots in the morning. Thanks Barry.
Can not attach an image.
When I click insert image icon it just says "" .
Can not drag either. Is there something I am missing?
It worked.....here is another screenshot.
So in the LIST I get IDs but not dimension. In the SCHEDULE I get dimensions but not IDs.
We will need to see the scheme settings for the schedule.
I am guessing you have not used 'Element ID' for the field or you are not using the element ID on the windows (you may be using another parameter?).
The list system is very old and has not been kept up to date for some years.
New elements like stairs and rails can't be used in lists.
Although the old elements like windows and doors should still work.
It has been a long time since I have used list so I am not sure why they are not showing the window dimensions.
poco2013
Mentor
I don't see a dimension field for windows in Lists - just width, etc. So i suspect your using a formula. A screen shot of your field configuration for the dimension field & your selected fields (properties & parameters tab) would help?
BTW -- seems to be working OK.
Gerry
Here is the scheme settings screenshot.
poco2013
Mentor
It would help if you included in your signature the version of Archicad your using and your platform. I suspect that 'things' have changed with 22.
Gerry
