IDs not showing up in schedules
Can' get window or door IDs to show up in SCHEDULES. HELP!!!!!!
10 REPLIES 10
pstady wrote:
Here is the scheme settings screenshot.
OK, you appear to be using the correct ID in the fields section for the Window ID.
Although you must be in an older version of Archicad as in 22 it is 'Element ID'.
Now the question is, are you using the actual window ID in your window objects (attached screen shot here is from version 22 info box), or are you using some other parameter in the window.
If you are using another parameter then you need to add it just like all the other object parameters (the 'Abc' icons).
