IFC Exporting similar walls in different ways
Hello everyone,
I am an engineer collaborating with architects, and we are currently looking into optimizing the translation of ArchiCAD models for Revit using IFC.
I've managed to create a model in ArchiCAD 23, export as IFC, import to revit, and keep working on that model using revit geometry. This is a great workflow that improves the teamwork on both sides.
However, the architect was not able to do so using ArchiCAD 22. I asked him to send his geometry to me wihch I opened with ArchiCAD 23. I found out that, although looking exactly similar, his geometry is being translated differently to IFC. Namely one is a wall, the other one is a building part (see screenshot attached).
I am a complete beginner in ArchiCAD. The question is, is there any hidden parameter that I am missing which explains why, in the same model, similar walls are exported in different ways?
The archicad model is here:
https://mab.to/rJPZNoDfR
Thanks a lot for your help,
Pedro
15 REPLIES 15
I think it would be beneficial for you to watch the playlist about IFC improvements in AC23. This may answer your question of why things are exported differently in AC23:
https://www.youtube.com/playlist?list=PLnXY6vLUwlWW3MmRDthnX5yeVJY7NIw6H
Hello and thanks LaszloNagy,
IFC 4 seems to be more interessant than 2x3 but is there a free reader which is able to open an IFC 4 today (on macOS) ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
thank you Ghaleb for your valuable post, it was exactly that the parameter that I was missing. I've seen it there however, as a beginner in ArchiCAD, I didn't realize how important they were. My question has been answered.
@LaszloNagy, thanks for the videos, I will forward them to the architect's team, I'm pretty sure they will find them useful.
Hope that other people will find this thread useful.
Christophe wrote:
... a free reader which is able to open an IFC 4 today (on macOS) ?
I found this free software which is able to open an IFC 4 here : https://www.bimcollab.com/en/default
Christophe - FRANCE
Aaron Bourgoin
If a composite wall hosts a door or a window, it doesn't appear in Revit as belonging to The Wall System family- a native Revit wall.
If this is a related problem, is there a way for a host wall to behave as other non-hosting walls which do?
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.1 USA
Rhino 8.25 Mac
MacOS Tahoe 26.1
Hello Aaron,
Do you talk about import an ifc into your BIM software then to modify it like by your original tools ?
If it is your aim, check this link :
https://archicad-talk.graphisoft.com/viewtopic.php?f=12&t=68521&p=304485&hilit=design+transfer#p3044...
Christophe - FRANCE
