IFC Library Objects only show on the lowest storey
fuzzytnth3
IFC Library Objects only show on the lowest storey of the Model despite being linked to a higher storey. In the attached screenshots you can see the settings for these objects so they should not be visible on the -3 Datum storey but they are.
The only solution I can think of is if I convert them to morphs and see if they will behave then. Anyone else had this issue?
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
fuzzytnth3
Converting them did make them behave but sometimes that can create a lot of polygons. In this case it didn't but seems like something that should work but isn't
Minh Nguyen
Thank you very much for your question and I am very sorry for the experience!
To better identify the issue, could you let me know a -step-by-step method how to reproduce it? This will be a huge help for us if we can easily recreate the issue in-house!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
