2010-03-02 07:01 PM
2010-03-02 07:05 PM
2010-03-02 08:47 PM
Matthew wrote:Tried that already, no luck. Can't delete it, it doesnt appear to even create the cut out.
It looks like the solid elements you are using to cut the openings are being exported. Try exporting visible layers only. You could also hide (or even delete) them in Revit.
2010-03-02 09:06 PM
2010-03-02 09:14 PM
Matthew wrote:Because it's an extruded slab, to create the wall panels. I can model it differently if needed. But do SEO's work at all when exporting as IFC? After a basic slab test I believe not unless I am missing a setting.
Why not just use doors instead of SEOs then?
2010-03-02 09:22 PM
2010-03-03 03:54 AM
2010-03-03 04:00 AM
Erika wrote:Tried both ways
If your SEO layer is set to wire frame try changing it to solid and then save out for IFC.
2010-03-03 04:24 AM
2010-03-03 04:29 AM
Erika wrote:AC 11,12 Constructor 2008, Vista
Please add your AC version and platform to your profile.
Which AC are you using?
