Perhaps you can post some screen shots of the trimming in revit, solibri and in archicad. How revit trims may be different than archicad.
Do archicad trims exported via ifc still function in revit?
Does solibri have special revit ifc translators?
regarding the doors you wrote
"which can only be corrected by individually editing each door individually,"
the parametric objects of both programs should allow you to select all the doors and edit the sill to_ height  collectively. Why are you having to select each one individually?
	Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
