IFC | "Classification Reference" field in Archicad 21
davdelven
Hello,
I would wanna ask if the new (AC21) Classification Manager allows to synchronize its data with "Classification Reference" field of the Standard IFC Scheme, which we are using usually applying Predefined Rules or editing XML classification files. (i.e. Uniclass 2015, OmniClass or others).
This link is the new "Classification Manager" on AC21 --> https://www.youtube.com/watch?v=mVjY4UoG7Sw
Custom Element Classification is useful if it matches or synchronizes with Classification Rules, most of them National or International Standards to apply into "Classification Reference" STANDARD FIELD (not custom).
Thanks in advance
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
11 REPLIES 11
davdelven
Good morning!
Has anyone managed how to mapping into a Custom PSet some sort code from the standard field ifcClassificationReference ?
It turns out that most IFC viewers (except Solibri) do not allow the filtering of the model through the classification field of the IFC standard, so there's no other option than to use custom PSet. In AC21 they have chosen that way, the one of the PSet customised to include the classification field, but without solving its synchronisation with the defining standard field with its Predefined Rules.
Some ideas, avoiding to use another additional XML with the new Classification Manager ?
IFC scheme has its own field to place this information, regardless market IFC viewers don't allow us to use it properly.
davdelven
After some tests... I got a result.
Thanks Stefan for your suggestion of using IFC Type Mapper in the IFC Translator. Although I had to edit choose a "DATA CONVERSION" option to allow exporting "Classification as ifcClassificationReference".
The only thing I still don't get it is to automate without user action, the "classification" info box option, switching on the desired classification system to be exported on each element.
I would like to avoid "dumb users" , who sometimes don't use "favorite tool" for modelling, not to do any action to classificate.
Any suggestion to automate this final "step" ?
