Identical elements are not considered together but separately
Dariy
Hello everyone,
I need to make a schedule for nested movable objects such as beds, sofas, wardrobes, etc. in a table in which to calculate how many pieces there are of each individual identical element, with the same dimensions and the same type. Unfortunately I have a problem with this, all the elements come out separately regardless of being in the same layer, one type and sharing the same description. I can't find any information anywhere and nothing helps, I'm also sending pictures for review of where I got it. I'm in a bit of a hurry due to deadlines, please help image_2024-08-13_021646528.png
Is 'Merge Uniform Items' turned on?
1 REPLY 1
Setup info provided by author
